on 25-06-2024 01:48 PM
My internet connection has been disconnecting for serval months. Recently it has got worse. I also have intermittent crackling on the phone. I was using the black Huawei hub and then the Sagemcom WiFi hub 2.
However they both were rebooting automatically. So I then tried a different setup with a router and modem. I used the BT Huawei Echolife HG612 provided by Talktalk a while ago, and a Eero Pro 6 router. The DSL on the modem did the same and kept dropping. I'm now using a Draytek Vigor 166 modem with the Eero Pro 6. Unfortunately this modem also dropped DSL. So it's fair to say it's the internet connection where the problem is.
I have now connected my modem to the test socket on the master socket. It's been connected for just over a week. As far as I know it hasn't dropped so far. I'm thinking it may be the faceplate on the socket that could be the problem? However I'm not 100% sure. It could be a line or exchange issue? I had an issue with the exchange over 10 years ago, where the filters needed replacing. Maybe it's the same issue, I'm not sure.
As there has been so many disconnections my speed has dropped from 58Mbps to 44Mbps. I'm guessing the DLM has slowed it down?
Please can you help,
Cheers,
John
on 26-07-2024 11:43 AM
Hi Karl,
Thanks for replying. I haven’t seen any improvements in speed. It’s staying at around 43-44 Mbps download. It’s been 8 days now since the fault was resolved. I’m still connected to the test socket and will give it another week to see if the speed improves.
As far as I know the connection has stayed stable. Although my speed was 44Mbps download up until Thursday morning, it seems just under that now. Do you know if the connection has stayed stable from your end?
Cheers,
John.
on 26-07-2024 11:33 AM
The current DLM profile is set to 80mb. Estimated speeds for the line are 47-52mb and the line is in sync at 47mb.
Have you seen any improvement ?
on 19-07-2024 11:14 AM
Thanks John, will do 🙂
on 19-07-2024 11:12 AM
You can do as I’ll leave it connected to at least then.
on 19-07-2024 11:10 AM
Thanks John.
Would you rather me check in again next Friday to see how the connection/speed has been?
on 19-07-2024 10:50 AM
Ok cheers, Debbie.
Thanks for the info regarding the cabinet.
I’ll leave it connected to the test socket, probably for another week or so just to keep it stable. My speed is still 44Mbps downloaded so hopefully it increases.
Cheers,
John.
on 19-07-2024 06:14 AM
Hi John
The notes advise that work was completed outside at the cabinet.
DLM should start to increase the speed again if the connection remains stable. Please can you leave the router at the test socket over the weekend just while DLM is monitoring the connection. I will check the connection stats/speed again on Monday.
on 18-07-2024 03:11 PM
Hi Debbie,
Thanks, it’s working fine at the moment. Do you know what the problem was?
My speed has gone up to 44Mbps download but that’s still at least 10Mbps slower than I was getting before any problems. Will my speed increase over the coming days or does the DLM need to be reset?
Also I’m still connected to the test socket, should I give it a few days or so before connecting back through the faceplate?
Thanks again,
John.
on 18-07-2024 02:38 PM
Hi @johnny95
Openreach have now closed the fault as resolved.
Is everything working ok at the moment?
on 18-07-2024 09:21 AM
Hi @johnny95
The fault has been assigned to the Openreach line engineer this morning. We should hopefully have further updates later this afternoon.
on 17-07-2024 01:11 PM
on 17-07-2024 01:08 PM
That’s great. Thanks, Debbie.
on 17-07-2024 01:04 PM
Hi @johnny95
No problem 🙂
If they find the fault externally and don't need access then they will just fix this fault.
If they do need access then they will let us know and we can then book the appointed visit. for you.
on 17-07-2024 12:59 PM
Ok thanks, Debbie. There could be a problem at the cabinet, but I guess they will check that as well. Thanks for keeping me up to date.
on 17-07-2024 12:39 PM
Hi @johnny95
I've passed this over to Openreach and they have advised that they will investigate on the line (externally) first.
I will continue to monitor for updates and I will post back on this thread.
Thanks again.
on 17-07-2024 12:23 PM
Yes please.
on 17-07-2024 12:21 PM
on 17-07-2024 12:20 PM
Hi Debbie. PM would be great.
on 17-07-2024 12:13 PM
Hi @johnny95
The line test is detecting a potential fault and Openreach are asking for us to arrange an engineer visit to the property.
Please can you provide your availability for this visit AM and PM?
Can you also confirm potential Engineer charges
on 17-07-2024 11:53 AM
An update. I’ve been connected to the test socket for three weeks. Unfortunately there have been a few disconnections that I know of. I think it must have disconnected over night a few times as well. As this morning my speed has dropped even further.
It’s steady getting slower. This morning my download speed test was down to 37Mbps, which is below the guaranteed speed of 42Mbps. I rebooted my modem and router this morning to see if it would improve but it’s staying at 37Mbps.( I was getting 58Mbps download approx 3 months ago)
Several years ago, the filters at the cabinet were changed. It may be the same issue now or maybe a line or other issue? I’m using a brand new modem and router so it’s not the equipment. Please could you book an engineer as this problem has been on and off for a couple of years now but recently has got a lot worse. My speed is dropping every 3 days or so now.
