on 14-03-2023 10:01 PM
I have reported via the online portal via network test a fault 3 times now.
Each time the fault clears (assume done). Same issue with very very slow internet speeds so run another check only for it to tell me there is a fault and it is being dealt with!
What is going on?
on 17-03-2023 07:44 AM
Hi Debbie
Would you like me to send a new router for testing?
on 16-03-2023 06:41 AM
Hi Debbie
Have we recently sent you a new router for testing?
on 15-03-2023 06:16 PM
No, the router is on 24/7
Even slower todfay
on 15-03-2023 07:45 AM
Hi @debbiec
All tests are currently clear, but I can't see the router online, are you turning this off ?
on 14-03-2023 11:33 PM
You are absolutely right to follow this up, @debbiec.
There are sometimes rather strange results on My Connection, with no explanation for the fault disappearing but reappearing when you run the test. No explanation about what is being done about it ....
Staff reply during the day, Monday to Friday.
