Slow wifi and no 5Ghz from Eero 6
jenny727
Message 64 of 64
I recently (sept 20th) had fibre 150 installed through talktalk, with the supplied Eero 6 dual band mesh router.
After open reach had finished the installation and set up the eero I connected my kindles,phone ect
to it. We did several wireless speed tests and it showed between 147 and 151 Mbps and a 5Ghz connection in the same room as the Eero.
All my TVs, PVRs, Desktop ect are all connected via Ethernet cables and speed tests showed a constant 151 Mbps. The next day however my wireless connection had changed from 5ghz to 2.4ghz on all devices and the speed had dropped massively to between 5 and 15 Mbps and this was in the same room as the Eero. The wired connection still remained at 151 Mbps. Tried disconnecting and reconnecting devices to no avail, still would only connect at 2.4Ghz and slow speed. Tried all trouble shooting tips, turning off 5Ghz, soft reset, ect but all devices still would only connect to 2.4Ghz. Ran two different wifi analizers and neither could detect 5Ghz only 2.4Ghz.
I have been having this trouble for 2 weeks now so Eero has had time to settle down but still no change.
Also if I move out of the room where the Eero is into the next room the speed droops right off.
Could this be a faulty unit or do you have any other suggestions.
I have also heard other people have had this problem and it has been rectified by being sent a Eero 6 pro as this is tri band and has both high and low 5Ghz frequency's as well as the 2.4Ghz.
Kind regard
jenny.
P.S – Before we changed to full fibre we had fibre 35 with talktalk. The dlink router was in the same place and the wifi signal was excellent throughout the whole bungalow and most of the garden.
63 REPLIES 63
Message 41 of 64
Thanks Jenny. I don't know why it's changing bands. Does the wifi analyser show all 2.4GHz channels congested?
jenny727
Message 42 of 64
Hi Chris,
2x kindle fire HD 10,  2x kindle fire HD 8, Roku's 4k streaming stick and lenovo laptop.
All the above show high speeds when connected to the 5GHz channel 42, control channel 36
but when eero channel changes to 5GHz channel 155, control channel 149/153 they all connect
to 2.4GHz and slow speeds and poor coverage.
Why is the 5GHz channel changing at the same time every day. If it remained on 5GHz channel
42, control channel 36 it would be perfect.
kind regards
Jenny
Message 43 of 64
Could I just ask which device you are running the speedtest on and getting the slow speed test results?
Message 44 of 64
I have read the Eero 6 pro is tri band and has both high and low 5Ghz frequency's as well as the 2.4Ghz
and cures this particular problem. do you know if this is correct.
Kind regards
Jenny.
Message 45 of 64
Hi @jenny727
Alas yes, you are right. I'll have to ask TalkTalk for you, if you could try a different router.
jenny727
Message 46 of 64
Hi Chris,
As far as I am aware you cannot change the channels on a Eero 6.
If I am wrong and you can, could you please tell me how to do this.
Kind regards
Jenny.
Message 47 of 64
Hi Jenny,
Could you give Keith's suggestion a try and let us know how you get on
Message 48 of 64
Hi @jenny727
The problem here is that not all Wi-Fi adapters in your various devices will not support channels as high as 155. Try changing the router to channel 36 for maximum compatibility.
jenny727
Message 49 of 64
Hi Chris,
Firstly thank you for sending the new Eero to me.
Changed the Eero's over using the app and everything was looking good.
All wireless devices connecting to 5GHz and good speeds recorded on
speed tests. Wi-Fi Analizer also detected strong 5GHz signal.
Unfortunately the next morning all my devices were back on 2.4GHz and
running slow speeds. Looking at the Wi-Fi radios page in the app it is clear
to see the 5GHz channel and control channel changed at about 03.00 am.
When devices do connect to 5GHz the Wi-Fi radios page in the app shows :
channel 42
control channel 36
when devices will not detect 5GHz Wi-Fi radios page in the app shows :
channel 155
Tried unplugging for 30 mins, soft restart etc but nothing would bring back the
5GHz signal. I then tried swapping Eero's again and everything worked fine again until
about 03.00 am when the channel and control channel changed again. Why would
it do this? and why at the same time every day?
I have sent three screenshots to show this.
Kind Regards
Jenny.
Kind Regards
Jenny.
Message 50 of 64
jenny727
Message 51 of 64
Hi Chris
Thank you very much hopefully things will be better on a different Eero.
Will be in touch when we have set it up.
Kind Regards
Jenny
Message 52 of 64
Hi Jenny,
I've ordered the eero, it should be with you within a couple of days
jenny727
Message 53 of 64
Hi Chris
Just to confirm profile is updated.
Kind Regards
Jenny
Message 54 of 64
Hi Jenny,
  • Name
  • Telephone number
  • Alternative contact number
jenny727
Message 55 of 64
Hi Michelle
Sorry been away on a short break so only just got this. That would be great if
you could send a replacement to see if it resolves the issue.
Kind Regards
Jenny
Message 56 of 64
Hi jenny,
I'm sorry for the delay. This would be a like for like swap. Would you like us to send this for you? We would also send a router returns bag so that one of the eeros can be returned.
jenny727
Message 57 of 64
Hi Karl
Unsure if you received last post as I have received no response or are you
just sending a different Eero to try to see if this cures the problem.
Thanks and kind regards
Jenny
jenny727
Message 58 of 64
Hi Karl
Thanks for your reply. Did you mean swap it for Eero 6 pro as this is tri band as others have said
this cures the problem or do you mean like for like.  As you are the expert I will go along with whatever
solution you think will best solve the problem.
Kind Regards
Jenny
Message 59 of 64
Would you like to swap out the eero and try another  ?
jenny727
Message 60 of 64
Hi Michelle,
 Powered down for forty minutes to be sure but after restart still exactly the same.
Disconnected and reconnected kindles phones ect but when reconnected still only connecting
at 2.4Ghz and slow speeds as described earlier. Ran wifi analizer again and still not showing 5Ghz .
All wired connections still remain constant at 151 Mbps .
Kind Regards
Jenny
