Zoom problems
philip_w_852
Message 8 of 8
Hi Everyone,
I have the Fibre 65 product and have had it for over two years with no issues.
Over the past few weeks almost every afternoon I have problems with Zoom - a video call is next to impossible and even turning my cam off - people still cannot hear me.  Wifi signal is strong. If I connect to a hotspot using my mobile or use the same device in the office I encounter no issues.
Openreach have been working in my area, and I now can get full FTTP fibre. Unsure if this is connected with the sudden onset of issues?
I have so far tried;
- restarting the router (several times!)
- using a new router TalkTalk sent me in February 2021
- used the master/test socket
- connected via ethernet
I'm at a complete loss - can anyone help?
7 REPLIES 7
Message 1 of 8
Hi philip_w_852
The Huawei hub is on its way, please allow 24-48hrs for this to arrive.
philip_w_852
Message 2 of 8
Yes please thanks
Message 3 of 8
Hi philip_w_852
Thanks for your reply. Would you like me to send a Huawei WIFI hub for testing so we can see how the connection compares with this router?
philip_w_852
Message 4 of 8
Hi Debbie,
Yes the new router is the same as the old one - a sagemcom hub. I don't have a huawei router to try.
Message 5 of 8
Hi philip_w_852
I can see that you currently using a Sagemcom WIFI hub, was your previous router also a Sagemcom hub?
Have you ever tested with a Huawei WIFI hub?
philip_w_852
Message 6 of 8
Yes it also happens when connecting via ethernet.
Also please note that this doesn't just happen on one device - it happens to two of us when working from home. When we take both devices into our offices - they work perfectly on Zoom/Google Meet/Teams.
It happens during the morning and afternoon, no specific time.
Message 7 of 8
I'm sorry to hear this. I've run a test on the line now which hasn't detected a fault and the connection stats also look ok. Can I just confirm, does the zoom issue also happen if you connect wired? Does it always happen at exactly at the same time everyday?
