Fibre/WIFI Issues
freweyni
Message 53 of 53
I’ve been having issues with my fibre speed. My Broadband speed has decreased from a consistent 37mbps (max that my package provides) to 29mbps. This currently below my minimum speed guarantee of 31.9mbps. Although 29mbps should be plenty enough to watch videos online, I’ve been experiencing video stutter consistently via WIFI. I’m also experiencing unbearable lag while gaming via WIFI.
Having accessed your support page, the speed test confirmed the slower speed to my router (see Picture) and when attempting to run a connection test, a fault was picked up, but a line test weirdly found no issues at all. The reference number to this fault is REP-12959300.
For the past fortnight, I’ve tried numerous troubleshooting options such as turning off the router for 30 mins, resetting the router and even connecting my router directly to the test socket, but none seems have solved the issue.
I’ve also accessed my router panel and I’ve noticed changes on my xDSL stats. These include my maximum downstream reducing from about 47500kbps to 28563kbps as well as having zero noise margin on my downstream. Also weirdly, my actual downstream rate seems to be higher than my maximum rate. Is this even possible? I’ve attached a picture of this for you to see.
I would appreciate it if this can be looked into and resolved as soon possible. Thanks.
52 REPLIES 52
Message 41 of 53
Message 42 of 53
Hi Debbie,
Thanks, i'll keep you updated.
Message 43 of 53
Hi freweyni
I've ordered a replacement router for testing, please allow 24-48hrs for this to arrive.
Let us know how the connection/speed compares.
freweyni
Message 44 of 53
Hi Michelle,
We don't have have any spare routers. Perhaps you can send out a replacement router to rule out our current router (FAST 5364) being the issue.
Anonymous User
Message 45 of 53
I'm sorry for the delay. I've run a test on the line now which is clear. Thanks for confirming that the router is connected to the test socket. Do you also have an alternative router that you can test with please?
Message 46 of 53
Ah, my bad, sorry I missed that.
freweyni
Message 47 of 53
Hi Ferguson,
I appreciate the suggestion, but as stated in my initial post, i've already attempted this and has failed to resolve the issue.
Message 48 of 53
Another useful thing to try would be if you can connect to the test socket, details here:
https://community.talktalk.co.uk/t5/Articles/Your-guide-to-main-phone-sockets/ta-p/2205432
freweyni
Message 49 of 53
Hi Divsec,
I can confirm the router is always connected and switched on.
Message 50 of 53
Hi Karl,
I'm unfortunately unable to do this as I haven't owned or used a home phone in over a decade. We use the landline for broadband only.
Message 51 of 53
Can you check the home phone, is there any noise, crackling on the line etc ?
All tests are showing clear currently.
Divsec
Message 52 of 53
Hi @freweyni your post has been escalated and you should hear during the day. Could you confirm that your router is usually connected and switched on?
Anonymous User
