on 02-03-2019 04:22 PM
more problems since the new webpage and I am really fed up, everytime I open the page my emails come up and then the page freezes at the bottom a yellow message comes up saying talktalk is not resoding , I refresh and the emails come up again and then the page freezes and so it goes on but I need proper access now!!!!!!
on 12-03-2019 12:41 PM
Hi chater
Have you had a look at this help page?
What to do if you can't load websites
on 12-03-2019 10:56 AM
no problems with other web pages only TalkTalk, page says …...talktalk unresponsive, please recover webpage which I do over and over again.
on 12-03-2019 10:48 AM
Hi chater,
I can see that Gondola has been helping you with this, how are you getting on?
on 10-03-2019 11:27 AM
Hi chater
The TalkTalk webpages / webmail pages aren't fundamentally different from any other internet site.
At this point, having tried different internet browsers, I'd try a different device so long as it's fully up to date with currently supported software.
In terms of troubleshooting the order of checking is:
Would you take a screenshot of the fault condition so we can see exactly what you're seeing. Image edit to remove any personally identifiable information and upload here using the photos icon above this reply area.
Like below to appreciate my help . . . Mark as solved Accept as Solution
on 10-03-2019 09:24 AM
on 03-03-2019 03:50 PM
...and you've switched off your security software temporarily?
and it's exactly the same if you temporarily use a different browser like Firefox?
on 03-03-2019 03:03 PM
have done as you advised but still doing it, I open the page it freezes, I refresh it does it again and on and on, help please, was ok last week
on 03-03-2019 12:18 PM
Hi chater
I'm running Windows 10 and have used Google Chrome without any issues.
Some security software can hold up the use of a browser so it might be useful to know what security software you're using. For example, Windows Defender, Kaspersky or Norton or SuperSafe Boost?
Troubleshoot with Chrome Extensions turned off.
Let me know what happens.
on 03-03-2019 12:06 PM
still doing it, did not have this problem before, I am windows 10 and use google , this has not changed, all these problems started with the new talktalk, and also my speed is only 6!!
on 03-03-2019 11:49 AM
Hi @chater
Remind us please of the Operating system and Browser you're using. For example, Windows 10 and Edge browser.
You've tried an alternative browser? I find troubleshooting is best when you test with a browser without any add-ons or extensions. For example, Firefox restarted with Add-ons disabled or Chrome with Extensions switched off.
